SERIOUS ISSUE: Corrupted Wildfire 4.0 files after update to CREO 2.0
RBobroski
Aerospace
Oct 11, 2010
44
Hey guys. Major problem I'm having here. We updated to Creo 2.0 from Wildfire 4.0 about two weeks ago. I haven't switched over however due to me being in the middle of a big design project that had to get finished. Two weeks go by, no real issues. Yesterday, however, in the process of me updating a hole size on a piece of sheetmetal 2 subassemblies deep I had a major crash. I was in the edit window (not edit definition) and adjusted the diameter and hit regenerate and all of a sudden I'm looking at my desktop; no error message, no lock ups or lag, nothing. I reboot my computer and I get an error upon shutdown that says something along the lines of "cannot write memory 0x000000000 for lmgrd.exe". Then upon restarting Pro/E some files keep getting corrupted. Some of them just trying to open brings me back to my desktop; some I can open but trying to view or regenerate or close the file crashes it. It isn't just corrupting the latest save files either but going several iterations down, ie if I have a screw.prt.12 that is corrupt screw.prt.8-11 won't work, but screw.prt.7 will.
Has anyone ever experienced anything like this? Would it have something to do with the update? Originally WF 4.0 license was on a server, when we installed CREO we moved the license file to the local machine, and I know lmgrd.exe has something to do with the licensing system. WF 4.0 is also only on M.040 and I am currently updating it to the latest build hoping it will resolve the issue. I can fins the corrupted files and delete them and redo some work but this isn't solving the root of the problem and I keep getting crashes and further corrupted files. Any help would be immense, as I'm at defcon 5 right now.
I would say the installation of Creo2 is not your problem. I suspect you have a hard disk going bad. There is no way that Pro/E is corrupting screw.prt.8-11. Once Pro/E writes a file it NEVER changes it. Do you have backups?
I do have backups of all my files on another network drive and most of my work is saved on a separate network drive so no data is pulled from my local machine save the license files now. I have no indications in my event log of a potential HDD issue although I may have missed it. The file that went corrupt was a family table file however..could the index file potentially get corrupt as well? It's hard for me to troubleshoot; I eliminated a couple of the fastener backups (moved to a diff directory) and eventually it opened up one that worked, but I also removed the index file at some point so I'm not sure if that did it.
Is there any way to check whether a file has issues without having to open and just experience a crash?
I would copy off those data files ASAP and attempt to read them from another computer. I agree with dgallup, first rule out hardware failures.
It wouldn't hurt to run a disk scan utility after you've copied off the data you can to see if it finds/corrects errors on that drive.
David
