You are indeed speaking of a large cage. Based on our recent experiences with some concentric cages up to 84" in diameter and 115 feet long, I have two comments. 1) More than 5 pick points and a good crane operator(s) are a must. 2) using an internal "mandrel" to help the pick is not a popular option. We identified that as one option and the contractor has refused to comply. Diagonal stiffners work well in addition to spiral stiffners on the outside of the cage. Be careful, we have watched a few hit the ground when some of the spiral steel slipped which was the tie-off point.
Make sure inspectors are watching the cages as they go in. If there is any rupture of the tiewire, have them redo it. If any of the CSL tubes rupture, have them reinstall them. After a few of these problems, the contractor becomes much more willing to take better care of the cage when suspending it.
Also, multi-section cages can work well, but you have to make sure you have the alignment issues undercontrol. Typically, we have used a short lower section (at that time the one loaded with 2 levels of O-cells), so that the splice is really not within an area of "high moment or shear" (I expect that 100 feet down, most of this has been disipated). Let's not use my last comment as a "theoretical discussion maker."
Be ready for some flexure and quantify what is acceptable in the specs. A well written spec makes it much easier to deal with the problems when they arise.
Zdinak
