I have worked with contacts (mostly small displacement) in the classic environment and have recently moved to WB. There seems to be something that I am doing wrong as none of my contacts seem to work (althought these problems I am working on are large displacement). So I setup a simple 2-link problem to see if my contact is even working. Imagine a steel chain with multiple links. Take any two links as the scope of the problem. Not fix one link (fixed support) and apply longitudinal force on the other.
I have tried to setup the contact two ways:
1) just select the interacting faces on the links. Set one link as contact and the other as target.
2) select one body as contact and the otehr body as target (all faces on both the bodies).
But my links never seem to interact. What could be wrong>? Is there a way to expeort a .inp file from WB environment so that I can post it here?
Thanks,
MAhesh
Thanks,
MAhesh
