Settings Problem - Inventor 2011
21Pom
131
AU
Hi All,
I have an annoying problem associated with some of my parts which are located on a USB stick.
On one computer I can alter the physical properties of a part say from aluminium to steel.
Yet, using the same file on the same USB stick on my laptop I cannot, I'm stuck with DEFAULT as the only option. Obviously I have inadvertently changed one of the setting but I cannot see which one. I have checked both computer setups on the Tools/Application Options and both are identical.
Can anyone tell me where I've gone wrong.
Best Rgds,
Dave R.
Hi All,
IT'S OK - FOUND THE PROBLEM AND SOLVED IT - NO NEED TO ANSWER.
Best Rgds
Dave R.
As I may be in the same predicament someday. What was the problem/solution?
