Settlement of organic silt
tpk72
18
All of the equations I have come across for settlement calculations differentiate between cohesive and cohesionless materials.
How do you calculate the settlement of organic silts? (ML/ OLs)? It is all weight of hammer blow count material (lake bottom), and has low cohesive values.
Do you just assume cohesive material, and calculcate primary and secondary settlement?
THanks
Step 1: Is it really an OL (i.e., did you follow ASTM D-2487 with the wet- and oven-dry-prep liquid limits and return a classification of "organic silt")?
Step 2: Do an odometer test with time readings that extend beyond the "end of primary" (i.e., so you actually have values of C-alpha).
Step 3: Interpret the e log p for Pp, Cc and Cr
Step 4: Do a settlement calculation for total consolidation settlement and a compression calculation for secondary settlement (this depends on a time-frame assessment for the project (i.e., how much compression will occur during the 20 years after construction).
In the absence of consolidation data, values for C-alpha are available from natural moisture content data, but first make sure that you actually have an OL or OH!
f-d
¡papá gordo ain’t no madre flaca!
