edison123
- Oct 23, 2002
- 4,501
I have just recd a 3.3 KV, 500 KW tube ventilated, fan cooled, totally enclosed (TEFV) motor for rewind. The motor (driving a cooling tower fan) has severe corrosion on the stator frame on the outside. Corrosion has eaten away top half of the frame to more than 4 mm depth. The terminal box welded to one side of frame has a clear hole right through the top due to corrosion.
Suppose, I cover the top half of stator frame with another 3 mm semi-circular mild steel plate with a clearance of say, two inches, away from the original stator frame, will it affect the cooling of the motor (due to loss of radiation surface and due to the air packet in between the frame and the top cover) ? If so, can anyone suggest alternative method of repairing these corroded areas ?
