hhmh2004
- Sep 11, 2011
- 18
In one of the jobs I have to specify a pump for domestic sewage transfer to waste water treatment plant. The Pump Flow is 290 USGPM and Required Head is 230 ft. The pump will take suction from an above ground Sewage Tank.
Here in Saudi Arabia, typically centrifugal non clog type impeller pumps are used for this service.
But due the required duty point specified above the centrifugal type of pump is not available in the market.
Second choice is to go for rotary lobe type of pump.
Is anybody familiar with use of rotary lobe pump in domestic sewege transfer?
Is it good in this service?
Does it require some kind of inlet protection i-e grinding or screening?
What is the maximum particle size it can pass?
Thanks and Regards
Thanks and Regards
