electricpete
- May 4, 2001
- 16,774
We have a 1.5 hp 460v motor driving close-coupled pump. There has been some damage to the shaft which is deemed not repairable
Replacement motor is not available due to the special shaft configuration.
Inspection showed the rotor core appeared tac-welded onto the shaft. I think it is a cast-aluminum rotor configuration - from the outside it just looks like a big steel can.
What has been proposed is to disassemble the rotor (remove shaft from rotor core), reverse-engineer a new shaft, and reassemble the rotor and motor with new shaft.
Do you see any problems with this approach or special considerations? We have a competent machine shop but they don’t work on rotating machines much.
(A preemptive strike – I am not interested in discussing alternate approaches for getting a replacement working motor... just what pitfalls or cautions we should consider for this approach. Thx!).
