Dear all,
while with drives applications with permanent magnet motors it is a common practice to share
the DCbus between drives, I've never come across a similar connection with VFDs (I refer to
manuals, case histories etc. - we have been using in time Japanese and European VFDs of different makes).
When there are for instance two identical async motors driven by identical VFDs why not connecting the DC
buses together to increase the current braking capacity ? Or one can save money using only one braking
resistor for two VFDs (of course if proper conditions are met for sizing the resistor, contemporaneity factor etc).
Or even do without any braking resistor due to the increased energy storing.
We work with low voltage motors in the range 0,75 kW to 4 kW with no special functions, simple
V/f applications and I am interested in your point of view.
Thank you
Thank you
