BigBakwas77
- Jul 7, 2016
- 34
I have worked previously in locations where British and Indian codes were in use. Both these codes consider the amount of flexural steel reinforcements (Tension as well as compression) in flexural members to determine shear capacity. Now I am working in Canada and CSA A23-04 does not utilize the value of the amount of flexural steel reinforcements while determining shear capacity. Surely one cannot assume that shear capacity of reinforced and un-reinforced sections shall be same. Am I missing something here?
