warickwrx
- Mar 19, 2013
- 34
Hi
When calculating the shear stress between two parallel plates which are moving in the same direction at different velocities with a fluid sandwiched in between is it advisable to subtract the two velocities namely ( V1 -V2 ), and assume the one bottom plate as now stationary with the resultant velocity as now only being the total for the top. The reason I ask is that one would think the shear stress in the liquid between the plates is less if both moving in the same direction. So hypothetical if a top plate moves at 2 m/s and bottom at 1m/s then new velocity is 1m/s for top with the bottom stationary.
thanks
