Shear stress on stacked HEB220 beams
FilleLJ
Industrial
Oct 25, 2024
1
Hello! I'm working on a garage with a vaulted ceiling on my property.
I've scored two HEB 220 beams from work and i'm planning on using these as a ridge beam for a vaulted ceiling. I've been playing around on Skyciv and they're plenty strong together.
However, it automatically bonded the beams into a composite, i'm wondering what the recommended method of attaching the beams together IRL is? I know that a bonded composite is stronger than two simple stacked beams.
What's making me confused is the shear stress I got (~50kN in each corner) from Skyciv, is this really it? That sounds like nothing to my untrained ears? Couple of M16/M20 8.8 bolts through the flanges and i'm all set? Better yet, run a couple of long welds along the flanges?
I was about to send these to the local ironsmith, but I could drill and bolt that pretty easily myself... Please help!
See attached file for the beam calculation from Skyciv
Excuse any English errors, it's not my native language
  • SkyCiv Beam Summary Report_D80B9zkq7lFGwpmfBcposmAQgkT7BgBD.pdf
I mean this in all seriousness... please hire someone competent to do this for you.
Thanks? As I said in the post, I was about to bring this to the local ironworker. They are certified in every aspect.
The framing calculations will be done by professionals aswell.
The very thought about attaching the beams myself sprung from the shear stress given by Skyciv.
It's a pretty straight forward question, no need to be uppity.
A simple "No, it doesnt work like that, it works like this and you should probably consult the ironsmith instead" sounds way nicer, but I guess you need social competence to figure that out
Sorry. What I meant to say was this:
It doesn't sound like you understand how this all works. Please consult a structural engineer local to your area and have them design whatever it is you're trying to achieve. This is not a job for an iron worker, and I very much doubt anybody on this forum will design it for you.
Google the concept of shear flow. You'll be looking for an equation of the sort that is VQ/It to determine the fastener spacing and capacity demand. It's generally thought that welds are the most appropriate form of fastening unless your bolts will be slip critical.
