Shear wall stress
SamETABS
37
0
0
IR
Hi Gents,
when we check the stresses
in the shearwall under lateral load and
gravity loads, wha would be the limits
for tension and compression stresses that
you can be sure of their performance.
many thanks.
This is code governed... You need to refer to the (concrete?) design standard you are using.
What code/standard are you using? Try to give more information and you might get more help.
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
