Sheet format will not print
PenDragon1970
Aerospace
Sep 20, 2005
12
I've looked thru past posts but I haven't come across the issue I'm having.
I'm creating custom borders/templates. I've modified a C size to become a D size, everything seems fine, but when I try to print preview, or even when I print, the entire contents are invisible. They won't print. What am I doing wrong?
Shane Polwort
Senior E/M Designer
Sierra Nevada Corporation
Solidworks 2005
Nevermind, I figured it out.
I assumed it must have something to do with print area since I created the D from the C and so many SW "switches" and such are carried over. I had to reset the scale factor. I imagine I'll have a lot of issues like this until I learn the interface in and out.
Shane Polwort
Senior E/M Designer
Solidworks 2005
Shane,
Welcome to Eng-Tips.... Solidworks is a lot of... "Hey, I just figured it out." But the people on this sight are great people.
I have a couple of old friends that work(d) at SNC... Spencer Ericksen...
Anyway, A trick we use for porting sheet sets from one sheet to another is to make them into blocks, move the block, then explode it on the new sheet. Works a little better than dealing with changing over the internals of a C into a D or E.
Good luck,
Wes C.
I appreciate the tip - just wish I learned it 2 days ago. Coming from an Autodesk background, not much in SW is intuitive or works the way I think it should.
I know Spencer [bigears]. He works up in ISR. Where you from?
Shane Polwort
Senior E/M Designer
Solidworks 2005
Spencer and were friends from High School, and Boyscouts. I havn't talked to him in probablly 7 years or so.
Carson City...
Alas, the transition is hardest from the Autodesk suite. But you'll you'll find it's easier (after the transition)
Wes C.
