I am trying to create a simple sheet metal box. I start off with a square sketch, then I create sheet metal. Now I want to 3 bends to be 90 degrees, and the 4th has to be 45 degrees.
What would be the best method creating such part. The problem I have is that I can't get the corners to be nicely closed (the same way as if it where 4 90degree angles in 1 bend-feature)
I have tried creating a shelled solid, then converting this to sheet metal. The problem with this method is that the 2 corners where the 90degree bends meet, are not really closed.
The attached image should make things a bit more clear.
thx in advance
thx in advance
