chrisnewzealand
I have had a bug with the sheet metal feature of SW2011, SP0.
I usually create sheet metal parts for door frames then do a 45° cut in the corners to create a mitre. When solidowkrs notices the 45° cut intersecting a faces normal to the sketch plane it jogs the cut, however for some reason it no longer jogs it and creates a straight cut line and bogus cut file.
How do I fix this, I need to know quite urgently as my bos wants the flat pattern files by the end of the day :S
