Sheet metal feature "use gauge table" to drive drawing block item "Gauge" 1
Not exactly what you are looking for but we use "Thickness@Sheet-Metal"STK in the part custom properties to display the stock thickness in our sheet metal template.
Diego
Thanks Diego. I think that has cracked it for me. Just needed to remove STK as we just show the gauge as a digit as per previous image.
Great!
Does that Property that you added automatically place the gauge dimension in the Property or do you still have to manually add the dimension from the part to the custom property value?
Scott Baugh, CSWP [pc2]
Gryphon Environmental
"If it's not broke, Don't fix it!"
faq731-376
Scott, "Thickness@Sheet-Metal" automatically puts in the gauge dimension, so it updates when changing the sheet metal thickness. We had an edict from on high requiring the gauge or thickness to be shown in the title block, rather than a drawing dimension. Not a fan of this but the new property automates insertion in the drawing.
Diego
