I'm drawing a solidworks sheet metal part. It is a subpanel (4 edges bent 1.0") with about 100 holes on it. It is 32" x 24". We don't manufacture it, we buy it from a sheet metal company that makes it for us. I would like to get an opinon threaded started on what the print would look like you would send the vendor to manufacture. Forget about calling the vendor, they say they accept napkin sketches. The reason I'm asking is that there are two mechanical engineers in my company, one being myself with 20 years of experience. Do you provide a flat view, do you ordinate dimension it (fyi holes locations from the bends are not important on this part), if you said no to the flat view do you just provide a solid model and drawing, do you dimension from the bend to a hole and then hole to hole? That kind of stuff.
