colombiu
Geotechnical
- May 26, 2014
- 2
Hello to everyone
I am trying to design and analyse a sheet piling wall for a project. As the site has the presence of rocks the client has found out that in some points the rock is just 200mm below the excavation level. Due to the depth of the excavation and my soil parameters,the toe-in length required to make the system stable is of about 2.0m which in this case is not possible to achieve due to the strength of the rock as our sheet piles would not go through it.
My question is: Is there any possibility to provide further stability just installing an anchor or a prop right at the bottom of the excavation to provide a lateral restraint? As there is zero passive pressure, it would help the wall to prevent the toe-in from kicking out. Additional to this, is there any way to calculate the factor of safety for this arrangement? Support-IT is not able to calculate any factor of safety for this arrangement if there is not any support (fixed or free) at the bottom of the vertical element.
If my idea is insane and not applicable for this case, could you advise for other solutions that I can carry on?
I hope to hear from you soon engineers! Thanks for your assistance.
Juan
Juan
