Does any one know how to do this ? We create some drawings of models with parts inside parts using multi-sheet drawings. Sheet 1 is the master weldment drawing where sheet 2 may be a laser cut weld in part. If for example I need qty 1 of the main drawing but need 2 of the sheet 2 laser cuts ... the "quantity" property we have is a drawing property and if I put a "1" in as this property is comes up on all sheet of the drawing file.
sw2009 sp3
sw2009 sp3
