Sheetmetal Question 1
BodyBagger
459
Hello all,
I have a simple sheetmetal part with 2 bends. I need to make a left hand and right hand version of it so I opened a new assembly with the left hand part, did a mirror (no merge) and checked the box for right hand and saved that part to its own file. When I went to make a drawing for the right hand part it does not have a flat pattern available. Is there a way to have the left hand/right hand parts associated and to have flat patterns for both?
Thanks,
BB
BB,
If I understand your question correctly, you are almost there.
In the 'Mirrored' part file, the new part should be a single feature with just a solid body (it is not a sheet-metal part yet, so no flat pattern)
You just need to select 'Insert Bends', select a fixed face, and enter your parameters.
It should now make it into a sheet-metal part with its own flat pattern (yet still linked to the original if changes are made).
Hope this helps.
MDGroup,
You were exactly right! Thank you for your assistance.
BB
nope... that is standard.
Occasionally you might get error flattening the mirrored part. You might have to open up the bend reliefs to get them to flatten.
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
I am using SW2009 SP4.1, and it worked flawlessly for me.
It took me a couple of tries to get the procedure right, but I figured it out in 2009 SP5.0. I was just misunderstanding how the check boxes work when mirroring. Glad to have learned how to do this.
As stated, this has worked in past versions, probably back as far as 2003. Nice feature for mirrored parts.
If rather than a mirrored part with a limited feature tree, you want to make a "save-as" part by reversing the direction of the sketches, make sure you check the side of the sketch the material is thickened on in Base-Flange1. This can bite the unwary.
regards, Diego
