Sheetmetal Slots - Standard ?
PCSControls
13
Is there a prefered/standard way to insert "slots" in a sheetmetal panel (aside from creating 2 holes and a cut between them).
Should be simple (and probably is) but I'm a rookie !
SW2004 Feature Pallete > Sheetmetal had oodles of predefined hole shapes ... doesn't SW2005 still have those?
Come to think of it ... doesn't SW2005 now have a sketch feature which creates a slot from a single line?
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
2005 still has slots: Design Library > Palette features > Sheetmetal > slot. They are super easy to make if there isn't one that you need. The easiest thing to do is right-click a part, "save as copy" and save as using the Lib Feat Part ".SLDLFP" extension. Refresh your library after modifying and saving.
Flores
Thanks for the quick response, I thought it would be easy, just had to know where to look !
