Kentucky_08
Chemical
Good day, everyone!
I am currently designing a cone-bottom vessel that is under vacuum. The use of the cone-bottom vessel is to receive the condensate coming from the vent condenser.
Can I ask for some questions since I am a new to this, and a starter in designing this one.
1. Should I have a separate calculation for the shell body thickness and for head in thickness for pressure vessel? I am confused as Figure UG-28.1 of ASME Section VIII part 1, it shows there the h/3 of the head must be added in length. If separate what length I must consider?
2. In connection to number 1,if separate solution is needed, what should I prioritize the head or the shell body?
3. What can you say about the cone-bottom vessel orientation considering that the external pressure it is under?
4. Is it right for me to choose the tori spherical head for the vessel since it is easier to fabricate and more economical since the vessel only needs to receive condensate.
Thank you,
Thank you,
