UtilityLouie
- May 3, 2001
- 102
I'm trying to replace an existing shell and tube heat exchanger that was oversized by quite a bit, but want to make sure I'm not missing a better piece of equipment for this application...
Fluid:
Glycol (40%)
EWT - 85 F
LWT - 115 F
GPM - 2000
Steam:
60 psig
I think with the big delta T between the steam and glycol is causing the problems. I've seen the welded plate and frame units with a super small contact area. Is this the right application for this unit.
Fluid:
Glycol (40%)
EWT - 85 F
LWT - 115 F
GPM - 2000
Steam:
60 psig
