For a shell model (ASME Sect. 8 Div. 2 analysis) of welded structures, when is it okay to average across part boundaries and when should you look at the parts separately? I realize solid sub models should be used to examine the welded areas because of discontinuities, but I was taught that it is okay to average across welded parts because the material is the same and these are full-penetration welds. But I remember reading somewhere that averaging should never be done between welded parts. Thanks
