Shell thickness calculation by One Foot Method for Joint Efficiency of 0.85
TheEverest
NP
How do we calculate thickness of shell according to One Foot Method (5.6.3), if Joint Efficiency of 0.85 is given?
Can anyone please help me?
Use 0.85 in the denominator of the 1-foot equation
API 650
(5.6.2.3 Appendix A permits an alternative shell design with a fixed allowable stress of 145 MPa (21,000 lbf/in.2) and a joint efficiency factor of 0.85 or 0.70. This design may only be used for tanks with shell thicknesses less than or equal to 13 mm (1/2 in.).)
You can find the required wall thicknesses based on maximum permissible shell-plate thickness 13 mm, allowable design stress of 145 MPa, a joint efficiency of 0.85 at Table A-2a.
The use of 1-foot method with joint efficiency for SI units td =(4.9D(H – 0.3)G)/(Ej*Sd) + CA
If it's an Annex A tank, use the equation in Annex A, which includes joint efficiency.
If it's not an Annex A tank, include the 0.85 in the denominator per IFRs' statement.
Note that API-650, in the main body of the code, assumes a joint efficiency of 1.0 (which is why joint efficiency doesn't appear in the equation) based on spot radiography, which is different from the vessel codes.
Thank you for your replies guys. These replies mean a lot to me.
