tuanphamanh
- May 12, 2005
- 7
I’m using Adina to model dynamic behaviours of an integral abutment bridge. In my model there are shell transition elements to model the connection between steel girder and the integral abutment (shell to solid intersections). The original model works ok with dynamic analysis.
Then I induced the damage to the model by removing one volume in the deck of the bridge and did the dynamic analysis again. The surfaces and nodes were renumbered by ADIA. I corrected the nodes, surfaces number problem for the damaged model. But this time, it didn’t work, the damaged model stopped and reported this error.
“A STIFFNESS DIAGONAL ELEMENT IS NOT POSITIVE BEFORE DECOMPOSITION.
NODE NUMBER = 131 DEGREE OF FREEDOM= X-ROTATION
EQUATION NUMBER= 262 THE ELEMENT VALUE= 0.000000000000E+00
*** ERROR NO. A1601 ***
Frequency-negative/zero diagonal element before decomposition.Incorrect model”
And if I remove the transition elements, the damaged model works ok. Is there any suggestion or help for me please?
