dik
- Apr 13, 2001
- 26,032
I have a bunch of end plate moment connections that may require shim plates to make up the length between a couple of masonry walls.
Is there a limitation about the number or the thickness of shim plates I can use. I was thinking about 1" thick plates for adjustment.
Dik
Dik
