Hello...
I am performing a shock test of a PCB assembly using Transient Structural module of Ansys Workbench. I am giving a peak load of 15 mm/s2 within a duration of 10 ms (peak load occurs at 5ms). I am using modal analysis results as initial condition for the simulation. However, the peak response happens at 4.6 ms which is less than 5 ms. If my understanding is right, the peak response should come after the time of peak input or at least at 5 ms.
Can someone please let me know why this happens and where am I going wrong with my analysis?
Thank you
Hari.
Thank you
Hari.
