I work for a company that prefabricates structural wall panels (all the walls in building, shear walls, load-bearing walls, non-load-bearing walls). I think that the EOR should be reviewing our shop drawings to ensure that our panels will match their design intent, but on a few jobs the engineer has not required the review of our drawings and the contractor has been the sole entity "reviewing" our shop drawings and signing off on them.
Is it really up to the engineer on whether or not they require engineering review, or should we, the manufacturer, be requiring an engineer's signoff? Everything that I've read basically says it's up to the engineer and contractor, and if the engineer doesn't require their own review, the contractor can take full liability and sign off themselves if they choose to. It doesn't seem like it should work this way to me. If this is really how it works can we even require sign-off from the engineer and architect?
I should clarify that we just pre-cut panel splices, window, door, electrical, and plumbing holes. All connections between panels and other framing are made onsite. We do not currently make different strength panels, the strength is determined by the onsite connections.
