I am trying to understand how to calculate the fault current that will flow on the primary of a transformer when the fault is on the secondary.
An example would be as follows.
When a transformer is rated, 1000 kVA, 5.75%Z, 13.2 kV-208/120V.
If there was a fault of approx 9000A on the secondary is there a simple method to calculate the amout of current flowing on the primary.
