Short commands don¦t work
HenricC
13
SE
Is there a setting for short commands? For example Ctrl+S used to work for Save but now it doesn´t. I only have this problem in AutoCad. Thanks/ Henric
Check out your help files under customization. This is a custom menu issue for shortcuts like these.
"Everybody is ignorant, only on different subjects." — Will Rogers
I think the solution is options-> customize settings (?)-> Windowkeys...(?)
L.
ADT 2004
ACAD 2002
Thanks a lot for the help.
It turns out that Cad and Windows have different accelerator keys and if you want to use the windows standard you find the setting under Options - User preferences - Windows standard accelerator keys, in case someone with thew same problem reads this.
You could also try this
Tools -> Customise -> Keyboard
From this dialog box you can define any keyboard shortcuts that you want. This is probably what Exxit is referring to.
By the way, this is for Acad 2005, but I'm fairly sure it's roughly the same for older versions as well.
