I am going through an arc flash remediation issue. The primary of the transformer is fed from a non fusible disconnect switch.
It is a 600 V primary system for a 225 kVA transformer.
They want to make sure that during secondary breaker operation on 208 V, arc flash hazard is limited to
Cat. 2
The suggestion was to use a fusible disconnet switch with current limiting fuse in parallel with non fusibible disconnect switch and open the non fusible switch.
Could you advise, if it is a smart and right thing to do.
Cat. 2
