Show Coordinate system with x, y, z axis annotation on drawing
Suslik1987
Computer
Mar 18, 2011
17
Hello everybody,
I want to show the Coordinate System on the drawing with axis annotation.
I can see the coordinate System on the drawing, but when I make a PDF File from it, the axis annotation with x,y,z is not shown. Is there any possibility?
Or do I have to create a custom symbel for this issue?
While the Axis and Planes of the CSYS will show-up on a PDF, the X,Y,Z annotation will not. However, if you were to first create a normal WCS object, hide the CSYS object and then export your PDF, now the Axis AND X,Y,Z annotation will show-up on your PDF.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Make sure that you're creating a WCS and NOT a CSYS. What version of NX are you running?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi John,
I am using NX 8.5. How I can create only a WCS?
There will be each time created a CSYS...
Thanks...
Ah I have it =)
I have to use Format-> WCS-> Save!
A WCS is at the beginning in the part.
But after user the save function, a green little WCs will be created =)
Thanks, it works!
