show / hide in multiview mode
suresh070379
62
In multi view mode, is it possible to hide a particular component in left window and show the same in right window. By this way, I can keep the whole assembly in left and any other single part only in right window. Kindly suggest.
Suresh
in the assembly window you can hide one instance of part A and have part A visible on its own window.
if you have a second window of your assembly, then the instance will also be hidden.
Eric N.
