Shrinking parts with dry ice 1
fareng
Industrial
May 24, 2005
7
I have seen dry ice used for shrinking fittings but I am not sure if I should use dry ice alone or with a liquid?
A low freezing point liquid is used to make the bath. Acetone or alcohol (both flammable) are often used.
Wear proper gloves and a face shield.
Slowly add small amounts of the solid dry ice to the solvent to avoid excessive frothing and overflow of the solvent.
Not sure if it gets as cold as alchohol bath but I have used household ammonia with dry ice with good results.
Griffy
Be careful with ammonia. It tends to attack certain metal alloys.
How much are you looking to shrink the part by? Even a common household freezer will work, with no safety issues, however still wear gloves.
