Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Minimum flow rate of centrifugal pumps is determined by the following criteria:
-temperature rise due to internal energy loss.
-internal recirculation in the impeller (with large
impeller inlet diameter compared with outside diameter,
the NPSH rises in the part-load range).
-increased vibration due to greater flow separation.
-increased pressure fluctuation at part load.
-increased axial thrust at low flow rates.
-increased radial thrust (especially with single-volute
pumps).
