planc
- Mar 3, 2022
- 64
In your experiences, how strong are corbel baseplates at the sides supporting an I-beam above it? Post installed anchors will be used (meaning there is already existing column/concrete).
See attached picture. The top baseplate where the I-beam frames into it has very insufficient anchoring, since the past contractor just put them before pour and another contractor just put the baseplate without adding post-installed anchors.
So one possiibility is to put corbel at the sides via a baseplate and anchors post installed. Questions.
1. Should the 2 plates be welded (top and sides)?
2. Assume the cone failure lines won't insect (between top and side anchors, we will design it that way). I'm just asking how strong are corbels baseplates generally in this message.
3. Please share what you actually did or seen. And some pictures or sketch. Thank you.
