Siemens NX - Rotation (twist) on pre-existing model
pB_9
Automotive
May 30, 2019
1
if you import stl file in nx(for example - twisted vase)and then create a surface, is it possible to "untwist" the vase?
Or, can you move and rotate (twist) certain surfaces on the model which was created by imported stl (like the features in NX realize shape - can it also be done on pre-existing model)?
Thanks for your answers
Yes and yes.
You can both unform shapes and you can apply "Global Shaping" to deform / twist .
Tomas
