SIF nozzlepro VS fesif
KVdA
49
Does anybody has an explanation on the outcome of SIF being different when calculating it using the FESIF module and nozzle pro module of PRG?
For example following input:
- Run 6" sch 40S
- Branch 2" sch 40S
- Branch angle 45°
Output:
Nozzle pro SIF for the run : ii=1.6 ; io=0.5 ; it=1.69 ; ia=1.76
FESIF SIF for the run : ii=1.21 ; io=0.5 ; it=1.27 ; ia=1.32
Nozzle pro SIF for the branch : ii=2.17 ; io=3.1 ; it=3.2 ; ia=3.9
FESIF SIF for the branch : ii=1.6 ; io=2.4 ; it=2.41 ; ia=3.4
Thanks in advance
I suggest you write this Paulin web site. You can get a true answer from the. But give them the versions of the software that you are using for the calculations.
