sight glass DN200 from CTP company
cremesti
18
0
0
GB
I have a cracked sight glass on one of the backwash waste lines in my sand filtration plant. I need a replacement. Our equipment specification lists it as:
CTP company product 360505
any idea which company this might be?
i cannot for the life of me find it online...
I am attaching a photo.
Best regards
rami
The sight glass is a component that was probably fabricated by the manufacturer of the filter system. Have you contacted the filter system manufacturer?
If you are discharging into a sump, you do not need the sight glass. In that case, install a pipe spool in place of the sight glass.
Steve it is Plastic. Bimr I have already contacted Christ Water the subcontractor for the filtration plant but there is no answer from them (they were bought out by GLV). Are there plastic transparent pipe spools??
Best regards
rami
Rami;
6 and 8-inch Sched. 40 clear PVC pipe is available in the US. My Pittsburgh supplier stocks it. The photo seems to show a length of pipe with a Van Stone style flange (2-piece) glued on to each end. I have made many of these and some smaller. When fabricating, be careful not to get any glue or primer on the viewing surface. With the Van Stone flanges, hole alignment is not important.
Steve
