Sign Wind Loads 9
dik
25,983
I have a bunch of little signs to design... different sizes on gravity bases.
I would normally use the projected area and use a force of design wind pressure x exposure factor (0.7), x wind pressure coefficient (1.3, for windward and leeward), x gust factor (2.5 rather than 2.0). They are temporary structures and I'd use an overturning factor of 3.
Does the ASCE or IBC have another prescribed approach? I don't have access to either document.
Thanks, Dik
azcats, thanks... not familiar with ASCE7, but, will look at it this weekend. I'll be using the Canadian Code for this. It appears to be a lot more simple. Other than a projectile in a windstorm, I don't see a sign as being a complicated item. It's the varied number of locations where it can be installed that might add to the complexity.
Dik
Another silly question. I cannot locate in the code where it stipulates a minimum overturning resistance other than the 0.9DL + 1.4LL. This is related to the National Building Code of Canada and the Ontario Building Code. Can anyone point to the requirement for a greater overturning resistance?
Dik
BB&Ron... where all growing older and less tolerant of 'silly things'.
Dik
Dik (damn autocorrect)- I thought we are supposed to mellow with age, like fine wine?[cheers]
So, what's your favorite whine?
Dik
Where's Henry Youngman when you need him.😂
Anyway Dik, no complaints this week; I'm on vacation this week. Currently in the Great White North; too bad I'm a few hundred miles east off you.
Take my phone....please.
faq731-376
