Signal interference with Tr!mlight system
CanuckPE
31
I've had a contractor at my house (single family) for several days. He's been endeavoring to figure out what's causing a signal interference issue with my Tr!mlight system that he installed. For days I suggested he, "figure it out for himself," but his presence at my the house is starting to grind on me. So, I'm going to pitch in to help the contractor. I'm a mechanical/structural engineer, so I'd like some help from the electrical crowd... please.
The basic issue is that when a wire (2 conductors, sheathed [each wire and the combo], speaker wire gauge) controlling a string of Tr!mlights is strung through the attic space above my garage, the downstream Tr!mlights occasionally have a flash of blue pass through the each light (note that the lights are able to vary color based on the controller settings, which I assume is voltage based). This blue streak occurs with the controller powered (i.e., plugged into the wall) even if the Tr!mlights are "off". With the system "on" and the Tr!mlights lit the same blue streak occurs occasionally (with similar or identical frequency). Frequency is in the range of one instance per minute. With the controller unplugged, the blue streak does not occur. When the same wire and same string of Tr!mlights is pulled out of the garage attic and laid on my garage floor, the blue streak does not occur. The issue is 100% reproduceable in all trials. I've seen it with my own eyes. He's tried several new controllers.
I suspect there's some sort of signal interference that's occurring in the garage attic. I have an elaborate system of wires (14-2) powering an old(er) school T5 CF lighting system (installed around 2016) for SUPER HIGH brightness in my garage. The CF bulbs are installed two-per-fixture, each fixture has one ballast in the fixture (not in the attic space), and there are about 15 fixtures in the garage (some 8' in length, and some 4').
On other variable is some exterior potlights around the perimeter of the garage (two per eave for a total of four, and three "near" the Tr!mlights).
As I'd prefer to not go back to the dark ages in my garage, I'm planning to shield the wires controlling the Tr!mlights from where the wires enter the attic space (or perhaps upstream to the controller box) to where the wires connect with the Tr!mlight string. Essentially endeavoring to create a Faraday shield around the conductors between the controller and string of lights. This is where I would like your help with a couple of things.
1. Does this (Tr!mlight shielding) sound like a good solution, or are there other avenues we should be exploring?
2. Do you agree the garage lights are causing the interference? If so, is it likely the ballasts, or hefty load of 14-2 power lines in the attic, or both? Is there a potential for the potlights to be causing the interference?
3. Does this have anything to do with wire gauge (i.e., the wires from the controller to the Tr!mlights)? If so, would larger gauge conductors potentially be a solution?
4. If we agree conduit shielding is likely to fix the problem, what shielding details do you recommend? I was thinking of galvanized steel conduits for the length of the attic complete with rounded corners and shielding uninterrupted from end to end. Standard Home Depot stuff. I'm wondering if each Tr!mlight wire deserves it's own conduit, or if we can buy one larger conduit and string the wires through he same conduit. I think there are four or five Tr!mlight wires in the attic.
5. Does a galvanized steel conduit act as a Faraday shield for the conductors inside the conduit?
I can post some photos if that's helpful.
https://trimlight.com/support/my-lights-are-stuck-on-blue-in-a-section
Perhaps the controller is experiencing a Wi-Fi signal interruption that it recovers from. But if it is cured by hooking it to a different circuit then do that.
Looks like there are three generations of Trimlight:
Trimlight Edge: 2021-Present
Trimlight Select Plus: 2018-2021
Trimlight Wi-Fi 104: 2015-2018
There are reddit threads about replacing the trimlight controller with other 3-wire controllers.
Google search "Trimlight Edge site:reddit.com"
Update:
Sorry, it's been a while.
The contractor returned to install all new "shielded" wire conductors from the controller to the lights. The shielding is essentially tin foil between the outer sheathing and the conductors. The shielding is obviously not grounded in this case. We changed the power supply to a circuit that is running one plug. The problem persists.
I'm thinking of reaching out to the manufacturer to see if they're able to get a "protocol analyzer to see who is sending the "blue" message", or "a digital oscilloscope that can store a string's worth of messages and a lot of time looking to see if the timing is correct.", or a "power quality analyzer."
Is there a device that could defect RF signals near the lights or in the area?
Also, would a generator be less prone to poor quality power?
An oscilloscope can be used without understanding the messages by simply looking to see if there is noise on the line or if the supply voltage is dropping too low. Too many lights on a weak power supply could cause the individual chips to reset when the voltage drops. It would take little time.
Also, try getting a controller, power supply, and light string that can just be laid out on the floor, possibly along the same path. If that doesn't have the problem then swap the easy parts first.
Ground your shield at the supply end only.
In any event ground at only one location.
