materialsguy
I am attempting to modify our testing procedures to eliminate routine QA testing for lubricating oils, greases, hydraulic oils, etc. Typically, these products are purchased by our maintenance sections for use in Department vehicles and equipment. We typically run flashpoint, viscosity / viscosity index, and pour point.
On a typical product, will these tests really give any good information? Can a company manipulate these numbers (mainly viscosity and pour point) to pass specifications while using cheaper materials? My speculation is that the testing we perform won't make much of a difference if we specify products listed on the API website of licensed products. If we eliminate testing of these products, we will have more room for other, more important testing equipment.
Also, for large diesel engines (ferry boats) will something like Total Base Number, possible TBN after 500 hours of use, give a good indication of quality for these harsh engine uses?
Thanks.
Jason Davis
Louisiana Dept. of Transportation
Materials Laboratory
Thanks.
Jason Davis
