MechyMarco
1. Tbuelna makes a very important point: 'rough machining' means 'machine to oversize, not to finished dimensions': and definitely DOES NOT MEAN to leave it with ragged/rough-edges and surfaces... which can be crack starters.
Generally speaking: IF You can run your bare fingers quickly all-over the parts and not get abrasions/cuts that's probably ‘good-enough surface-finish for rough machine parts’, at this stage. IF YOU get hurt doing this the surface is too rough to safely SHT.
2. Also, SHT/Q, followed by first temper operation is by-far the critical operation... to stabilize the part in approximately final temper state [W/~80--90% grain transformation completed]. I think-of the second temper operation
simplistically as the 'completion-temper'... whatever grain/metallurgy transformation was not accomplished with the first temper operation is completed by the second operation [to reach ~100%]. And it is a stress-relieving operation also.
When the heat-treat, machining and plating processors are widely separated [sometimes hundreds of miles apart], I prefer that the heat treater do BOTH tempers steps
to 'giterdone'... then have the part finish-machined[ground]... then have the plater do a true [post machining] pre-plate stress relief operation.
However, one prime vendor we had nearby [who did all machining operations] was just down the street from their heat-treat processor and had a great relationship with them... so doing the rough-machine/first-temper/finish-machine/second-temper process efficiently was common 'stuff' for them [our aerospace work was a 'small job' for them, compared with their on-going local AG/diesel-engine work].
NOTE. Heat-treaters are sometimes called-upon to do interim re-annealing operations when lots of steel-cutting [in the low-temper state] is required... and surface hardening or distortion is noted.
3. CAUTION!! One of the hardest 'elements' that all the processors had was getting their ‘people’ [machinists/techs/transporters/etc] to recognize that on-going
flash-rust and impact-damage prevention was serious business! These parts have-to-be-protected by corrosion preventatives and packaging from incidental corrosion and handling damage between operations [oil, CPC, VCIs, barrier papers, heavy duty impact-absorbing wood/cardboard/boxes/crates, etc].
4. NOTE, regarding shot peening...
Generally speaking, for steel and CRES parts HT ~200-KSI [depending] and above, special peening shot and processes are required.
Specify high Intensity peening levels and high hardness steel shot [cast or cut-wire].
Intensity will depend on localized material thicknesses and M&P or specification recommendations.
‘High hardness shot’ [cast or cut wire steel] should be per AMS2431/2 or /8 [and maybe /5], or equivalent. ‘Regular hardness shot’ will NOT actually peen very/ultra-high strength/hardness steel materials.
Also, I always recommend 200% [2.0] coverage, thus… peen it 100% [1.0] all-over-once… then peen it the same way, again!
NOTE.
Peening compresses the surface for fatigue improvements [to retard crack initiation]; and also ‘hardens’ the surface for improved impact and wear resistance.
Some generally useful peening specs & info…
AMS-S-13165 [cx, good info] Shot Peening of Metal Parts
AMS2430 Shot Peening, Automatic
AMS2431 Peening Media
SAE HS-84 Manual on Shot Peening
SAE J2441 Shot Peening
Curtis-Wright [Metal Improvement Co]
NOTE: AMS2546 Laser Peening [W/O shot!] might also work… but unsure…
Regards, Wil Taylor
o Trust - But Verify!
