mfgenggear
Aerospace
- Jan 23, 2008
- 3,371
The subject is
super finished gear teeth which then require silver plate over gear teeth profiles, including the major diameter, roots, & end faces.
the issue I am having is I have customers that wants a 4 micro
on their tooth profiles. similar process to ISF Isotropic Super finish Process. However my suppliers complain that the plating process will not adhere to the parent material. It will peel off after the post embrittlement bake operation. the bake can only be 275 Deg F because these are Carburized parts.
what the suppliers normally do is an abrasive (glass bead peening) which roughs out the surfaces to make the plate stick.
which of course this is not acceptable because it violates the 4 micro.
what is this boards recommendations, I looking for constructive suggestions. or is there a process which will make the plating stick to the super finished gears.
can the super finish be 15-20 micro. so the plating will adhere.
I am at a loss with this scenario.
Thanks in Advance
Mfgenggear
Thanks in Advance
Mfgenggear
