Simple Deflection Question 1
Brobocop
23
The code deflection limit charts for Floor Members simply states:
Live load = l/360
Nothing for Wind
D+L = l/240.
So am I only checking the Live Load deflection and the Load combination (D+L) deflection?
Does my Load combination of D+0.75L+0.75(0.6W)+0.75Lr not need to meet l/240? Or is 0.75L+0.75(0.6W)+0.75Lr considered the "L" in D+L = l/240
Where were wood beams mentioned initially?
Quoting ACI318 Table 24.2.2, For the case of members
Not supporting or attached to nonstructural elements likely to be damaged by large deflections
The only check required is LL deflection of L / 180 for roofs or L / 360 for floors.
The total deflection checks are only required for members
Supporting or attached to nonstructural elements
retired13 29 DEC19 18:26 said:
You should point to another thread you've posted, so new readers wouldn't be confused.
