civil2013
- Feb 27, 2005
- 24
hi, i am analysing a simple frame structure - composed of a horizontal beam and a vertical column (the frame looks like '7' with 6 dofs restrained at the bottom of column)... i have prepared the stiffness matrix for the strcture, now need to prepare the force matrix..... i need to analyse the structure only for the dead weight and wish to know how to consider the weight of column in the force matrix. understand that the beam weight can be applied as momement and vertical shear at the beam ends, how to consider the column weight - is is just applied as equal point loads at the top and bottom ? thanks
