jball1
- Nov 4, 2014
- 78
I am trying to build a really simple model to help me understand connectors in Abaqus. Here is my model:
I feel dumb, but I can't figure out how to connect one end of the wire that represents the connector to the node at the center of the shell element mesh. I am creating the wire in the interaction module. When I bring up the "create wire feature" menu, I can only select points, not nodes.
I tried just creating a point at the center of the mesh in order to create the wire, and then I created a tie constraint between the point at the end of the wire and the point at the center of the mesh. This solves, but I am not getting any load into my plate.
The connector has a stiffness of 1000 lbs, and the load is 100 lbs. I have also tried simply increasing the load and that has no effect. I have attached my simple input model below. I would greatly appreciate any help. Thanks!
