gharli
- May 28, 2015
- 42
Hi All,
Simple question (hopefully).
If there is a continuous system with a discreet point load, over what length would it be reasonable to calculate over-turning stability?
For e.g. a rigid wall that is continuous and has a continuous overturning force induced by soil pressure. This is easy, take a 1 m strip and do the math(s). Brackets if you're British.
But if the wall is continuous and flexible (say a steel mesh) and the load is a discreet point load, what length of wall would you consider for the stabilizing effect of self-weight? The wall in this case could fall over locally, i.e. twist from being vertical far away from the load to horizontally flat where it has fallen over. My feeling is that the length is a function of the torsional stiffness of the wall. If this is the case, then how to we solve this problem practically?
I hope the question is clear, would appreciate your thoughts/views.
